My first Acoustic Guitar build... http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=40899 |
Author: | superspeedo [ Tue Jul 16, 2013 4:41 pm ] |
Post subject: | My first Acoustic Guitar build... |
Author: | superspeedo [ Tue Jul 16, 2013 4:51 pm ] |
Post subject: | Re: My first Acoustic Guitar build... |
[img][IMG]http://i1292.photobucket.com/albums/b568/superspeedo007/1361126383870_zps8dcd49bb.jpg[/img][/img] ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Author: | superspeedo [ Tue Jul 16, 2013 4:55 pm ] |
[img][IMG]http://i1292.photobucket.com/albums/b568/superspeedo007/FA1F051E-C11C-41F2-80E8-F59BC0E10545-4767-000006076B733F28_zps5002a61b.jpg[/img][/img] ![]() ![]() ![]() |
Author: | superspeedo [ Tue Jul 16, 2013 4:56 pm ] |
Author: | superspeedo [ Tue Jul 16, 2013 5:00 pm ] |
What im finding hard is attaching the neck to the body and what method to use, anyone got any ideas? |
Author: | PeterF [ Tue Jul 16, 2013 5:40 pm ] |
Bolt on butt joint or bolt on M+T joint is easy: http://www.cumpiano.com/Home/Articles/S ... block.html. M+T is easier if you prep the neck block before gluing to the body. You just need to make more jigs like this. |
Author: | theguitarwhisperer [ Tue Jul 16, 2013 6:04 pm ] |
A dovetail can be cut with inexpensive hand tools, a saw and a chisel, it's easier if you haven't glued the fretboard to the neck yet. The chisels must be extremely sharp, but you can do the whole procedure easily. If you have a problem fitting stuff you can shim and redo it until it's right. |
Author: | Rodger Knox [ Wed Jul 17, 2013 1:04 pm ] |
theguitarwhisperer wrote: A dovetail can be cut with inexpensive hand tools, a saw and a chisel, it's easier if you haven't glued the fretboard to the neck yet. The chisels must be extremely sharp, but you can do the whole procedure easily. If you have a problem fitting stuff you can shim and redo it until it's right. I don't think fitting a dovetail can be done easily, even with extremely sharp chisels. ![]() It will NOT be easy the first time! I've only done one, so I don't know how many it takes before it can be done easily. ![]() You can shim and redo until it's right, I think I made 3 sets of shims before I got it close enough. |
